1/2 inch Hexes - Standard Flatland
SKU: TM1
1:1200 Scale 1:160/10mm/N-Scale 1:2400 Scale 1:285/6mm Scale Other Hexes
 More payment options
Terrain Maker® is a geomorphic wargaming terrain system based on double-density Styrofoam hexes measuring four inches from side to side (Terrain Maker hexes are 4" from the middle of one side, through the center of the hex, to the middle of the opposite side.) The thickness of the hex determines the type of terrain it models.
PER PACK: TM1 contains 24 hexes (1/2" thick) plus enough tree material to make 16 trees, and instructions.
This is the standard ground level Terrain Maker hex. Use TM1 to model roads and all ground-level terrain. Also used as bases for all elevation levels.
(The photos above show terrain made with TM1. Vehicles and buildings sold separately.)
**PLEASE NOTE - Due to the high costs of shipping Terrain Maker outside of the contiguous USA, the standard 20% of the merchandise total that we charge for international shipping is not sufficient.
If you live outside of the contiguous USA and are interested in purchasing Terrain Maker, please contact GHQ at customerservice@ghqmodels.com to tell us where you live and how much Terrain Maker you are interested in purchasing.
We will then respond with an estimate for your shipping costs.
Thank you.
  • Scale:1:1200 Scale
  • Scale:Other
  • Terrain Maker:Hexes
